Old 08-11-2015, 04:18 AM
mape2k mape2k is offline
Draw order of vizinfo Panel
Hey,
how can I change the draw order of a vizinfo panel? I have a normal vizdlg panel in the background and want to overlay it with a vizinfo panel to get some participant information.
The vizinfo panel is always hidden behind the vizdlg panel. Even if I hide the background panel (alpha = 0), I cannot use the mouse or keyboard to input anything into the vizinfo panel.
Cheers,
Johannes
Old 10-06-2015, 02:24 AM
Nobody knows a solution?
Old 10-08-2015, 02:59 PM
You could change the vizdlg panel's drawOrder to render the panel above or below:
Press 1 to set vizdlg panel above
Press 2 to set vizdlg panel below
import vizinfo
import vizdlg
myPanel = vizdlg.Panel(drawOrder=-10)
label = myPanel.addItem(viz.addText('This is the vizdlg panel'))
textBox_panel = myPanel.addItem(viz.addTextbox())
viz.link(viz.CenterCenter,myPanel,offset=(-100,50,0))
info = vizinfo.InfoPanel(title='This is the vizinfo panel',align=viz.ALIGN_CENTER_CENTER,icon=False)
textBox_info = info.addLabelItem('TextBox',viz.addTextbox())
def setPanelAbove():
	myPanel.drawOrder(10)
def setPanelBelow():
	myPanel.drawOrder(-10)
vizact.onkeydown('1',setPanelAbove)
vizact.onkeydown('2',setPanelBelow)
vizinfo, vizdlg related questions mape2k Vizard 4 07-27-2015 03:46 AM
check user input using vizinfo panel armo Vizard 0 01-22-2015 02:05 AM
how to draw a single point aaaa Vizard 2 11-17-2014 01:26 AM
one panel over all windows Andy Vizard 5 04-11-2012 09:24 AM
Problem Vizdlg panel draw order Chapre Vizard 1 05-17-2011 02:29 PM
