To Jeff,
SMI said that I would not require the iView X application. They therefore did not supply me with a licence key for the program. It could be the case that it might just not be possible. The manual also talks about iView X, and not iView ETG. This is really odd though, because Worldviz and SMI are partners, you would expect the stuff to run flawlessly. Any other thoughts? Thank you. p.s. We recently bought the glasses. They were very expensive (about 10.000 euro's) you would expect that such a system would operate without any trouble. The iView ETG application clearly works, but I would also expect that the interface to vizard would work without any trouble. The manual supplied within the iView SDK isn't totally finished. It only contains C++ interface examples. The python interface examples are left blank. By the way, there is a difference between python and Vizard python, although I think that the python code should also work within vizard, probably not the other way around. |
| Thread Tools | |
| Texture Coordinates in a Cube Map | mshukun | Vizard | 2 | 05-10-2013 01:31 PM |
| How do coordinates in IS900 thransform into coordinates in vizard's world | jacky | Vizard | 1 | 08-11-2011 11:44 AM |
| how to add the system path of Arrington Application | mouweimin | Vizard | 3 | 06-08-2011 10:30 PM |
| viz.vertex coordinates | lilio | Vizard | 6 | 05-16-2009 05:36 PM |
| Free Walkthrough Application Code | Gladsomebeast | Vizard | 0 | 03-03-2009 05:02 PM |
