Old 10-15-2014, 10:39 AM
Alex Miranda Alex Miranda is offline
I know, but if I change any number everything will change! I would like to know which criteria are used to choose this constants.
For example: Why width is 3.048 and width_2 is ( Width / 2 ) and depth is equal the width?
Old 10-15-2014, 10:51 AM
Those are made up values for the example. In an actual setup you will need to define the dimensions of each projected area (wall) in your trackers coordinate system. Once your tracking system is setup and calibrated, you will need to determine the 3D coordinates of each corner of the wall relative to the origin of the tracking system.
A wall is essentially a window into the virtual world. In order to render correctly, the system needs to know where the users head is in relation to the physical wall. This means the tracker you use to track the users head position needs to be the in the same coordinate system as the wall dimensions.
Cave Collision problem TopazFrost Vizard 2 02-13-2014 02:34 PM
[New here] Cave joy navigation esuna114 Vizard 2 06-11-2010 04:36 PM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 10:12 AM
CAVE, navigation, tracked wand, coordinate systems JimC Vizard 6 10-09-2009 12:43 PM
