Old 10-09-2014, 07:03 AM
BSUGeek BSUGeek is offline
Question Vizard export to xml file
I'm creating a program that receives the data from the timer and the avatar position. I was wondering is there a way to export that data into an xml file and change the timer format to output MM:SS instead of seconds and milliseconds? and for the avatar can you just get the X position instead of the full x,y,z position?
Vizard .exe file doesn't load (Vizard 3) Saule Vizard 4 02-05-2014 07:01 AM
Interaction of vizard objects with an imported obj file sunil.nair Vizard 2 10-09-2013 03:08 PM
Export from 3Ds Max to Vizard pattie Vizard 5 08-26-2006 12:20 PM
female skeleton CSF file needed to export to CAF format vmonkey Vizard 1 10-04-2005 11:15 AM
