Old 08-22-2014, 12:48 PM
Alex Miranda Alex Miranda is offline
Cave
Hello everyone,
I've tried to develop for the CAVE environment, but I'm having any troubles to sync all images... Is there a plug-in that I can use?
Old 08-26-2014, 01:51 PM
Kevin Chiu Kevin Chiu is offline
Hi Alex,
Are you doing it from a single computer?
If not then you will need to use Vizard's cluster system which will require Enterprise license.
There also some information that you can take a look and try it by yourself first.
http://docs.worldviz.com/vizard/Vizcave.htm
http://docs.worldviz.com/vizard/vizc...le_machine.htm
http://docs.worldviz.com/vizard/vizc..._clustered.htm
Best,
Kevin
Old 08-26-2014, 05:55 PM
I'm doing it from a single computer, but after I'll do from a Cluster.
Cave Collision problem TopazFrost Vizard 2 02-13-2014 03:34 PM
orthographic projection in a head-tracked cave environment michaelrepucci Vizard 5 12-14-2011 11:29 AM
[New here] Cave joy navigation esuna114 Vizard 2 06-11-2010 05:36 PM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 11:12 AM
CAVE, navigation, tracked wand, coordinate systems JimC Vizard 6 10-09-2009 01:43 PM
