Old 08-21-2014, 01:14 PM
The following is a short example script that loops through 3 trials in a task function. Each trial loops for the number of images in the images list. For each image loop the program waits for either the 'y' or 'n' key to be pressed:
import viztask
import random
#Store images in list
images = []
def experiment():
	#Repeat trial 3 times
	for i in range(3):
		#Use random.shuffle to put images in random order
		random.shuffle(images)
		#Cycle through images
		for image in images:
			#display image
			#wait for 'y' or 'n' key to be pressed
			data = yield viztask.waitKeyDown(('y','n'))
			print data.key
			#remove image and let user know if response is correct
viztask.schedule( experiment() )
Old 08-22-2014, 09:55 AM
bobbin_93 bobbin_93 is offline
That's absolutely brilliant, thank you so much for your help it's really helped me to put the experiment together!
I have one more question however.
Within my 15 insects there are 5 'models' and 10 mimics'. Models sting, whereas mimics don't and therefore I need to display different answers for each - which I am having trouble with.
Here's the code that I've put. In the images the models are labelled 1 to 5 and the mimics are labelled 6 to fifteen. I've also tried seperating them into 2 seperate lists 'stinging' and 'non-stinging' however, the problem with this is I then can't get them to shuffle randomly between the two. Any ideas?
images = [one,two,three,four,five,six,seven,eight,nine,ten,e leven,twelve,thirteen,fourteen,fifteen]
def testPhase():
for i in range (3):
#Make background visible
background.visible(viz.ON)
#Add focus point
focus.visible(viz.ON)
#Use random.shuffle to put images in a random order
#Wait 3 seconds for participant to look at focus point
yield viztask.waitTime(3)
#Remove focus point
focus.visible(viz.OFF)
#display image
image.visible(viz.ON)
#Mark the time the programme started
start_time = viz.tick()
question_data = open('experiment_data.txt','a')
#Wait for 'y' or 'n' key to be pressed
d = yield viztask.waitKeyDown(['y','n'])
elapsed_time = viz.tick() - start_time
#write data to file
if image == one or two or three or four or five:
if d.key == 'y':
image.visible(viz.OFF)
data = 'Participant' + ' Thinks the insect would sting.\t'
correct.visible(viz.ON)
correctPoints.visible(viz.ON)
info.visible(viz.ON)
if d.key == 'n':
data = 'Participant' + ' Does not think the insect would sting.\t'
wrong.visible(viz.ON)
wrongPoints.visible(viz.ON)
if image == six or seven or eight or nine or ten or eleven or twelve or thirteen or fourteen or fifteen:
if data == 'n':
if data == 'y':
#add elapsed time to data
data = str(image) + data + ' Elapsed time was: ' + str(round(elapsed_time,2)) + ' seconds\n'
#Write the data to our file.
question_data.write(data)
#Press space bar to start the game
yield viztask.waitKeyDown(' ')
#Remove score
correct.visible(viz.OFF)
correctPoints.visible(viz.OFF)
wrong.visible(viz.OFF)
wrongPoints.visible(viz.OFF)
info.visible(viz.OFF)
viz.quit()
compiled exe won't save trials to AVI krimble Vizard 1 01-29-2014 12:32 PM
running experimental trials fivel_lab Vizard 3 03-18-2011 03:58 PM
