Old 08-20-2014, 09:53 AM
bobbin_93 bobbin_93 is offline
How to set up trials?
I'm wondering if anyone can help me. I've designed an experiment but unfortunately since I'm not really familiar with vizard or coding I've coded for it very long-hand.
I've been told that before I can get the experiment up and running I need to re-organise my code to get it running in a loop of trials, however, I have absolutely no idea how to do this!!!!
I've copied the code below. If anyone could give me any pointers that would be fantastic
p.s. I've not copied the full code as it goes on forever but essentially there are 10 repeats of the same thing in the test phase!
import viztask
import vizinfo
import vizmat
import vizshape
viz.setMultiSample
viz.fov(60)
viz.window.setSize(-1); #set to full screen
#Add score labels for trial 1
success = viz.addText('You ate the insect!', viz.SCREEN)
success_points = viz.addText('+5 points', viz.SCREEN)
fail = viz.addText('You got stung!', viz.SCREEN)
fail_points = viz.addText('-5 points', viz.SCREEN)
info_one = vizinfo.add('Press the space bar to try again')
info_one.translate(0.70,0.3)
#Make score labels invisible
success.visible(viz.OFF)
success_points.visible(viz.OFF)
fail.visible(viz.OFF)
fail_points.visible(viz.OFF)
info_one.visible(viz.OFF)
#Add score labels for trial 2
successTwo = viz.addText('You ate the insect!', viz.SCREEN)
success_pointsTwo = viz.addText('+5 points', viz.SCREEN)
failTwo = viz.addText('You got stung!', viz.SCREEN)
fail_pointsTwo = viz.addText('-5 points', viz.SCREEN)
info_two = vizinfo.add('Press the space bar to try again')
info_two.translate(0.70,0.3)
successTwo.visible(viz.OFF)
success_pointsTwo.visible(viz.OFF)
failTwo.visible(viz.OFF)
fail_pointsTwo.visible(viz.OFF)
info_two.visible(viz.OFF)
def participantInfo():
#add the vizinfo box
infoBox = vizinfo.add('')
infoBox.scale(2,2)
infoBox.translate(0.85,0.8)
infoBox.title('Participant Info')
#Add the GUI elements to the box
participantNumber = infoBox.add(viz.TEXTBOX,'Participant Number')
experimentNumber = infoBox.add(viz.TEXTBOX,'Experiment Number')
runButton = infoBox.add(viz.BUTTON,'Run')
#Wait for run button to be pressed before moving on
yield viztask.waitButtonUp(runButton)
#get data from text boxes and then remove the info box
participant = participantNumber.get()
number = experimentNumber.get()
infoBox.remove()
#open a text file
experiment_data = open('experiment_data.txt','a')
#write participant data to file
data = "Experiment Number: %s\tParticipant: %s\n\n" % (number,participant)
experiment_data.write(data)
def learnPhase():
#Add grass background
quadTwo = viz.addTexQuad(pos=[0, 1.8, 1.7], size=2.75)
textureTwo = viz.addTexture('Grass.png')
quadTwo.texture(textureTwo)
#Add insect example
quadOne = viz.addTexQuad(pos=[0,1.80,1.6])
texture = viz.addTexture('model_one.png')
quadOne.texture(texture)
#Add instructions of what to do
instruction = viz.addText('Eat insects to score points!',viz.SCREEN)
instruction.alignment(viz.ALIGN_CENTER_TOP)
instruction.setPosition(0.5,0.9)
info = vizinfo.add('Press the space bar to begin')
info.translate(0.65,0.2)
#Start test phase with space bar
info.remove()
quadOne.remove()
instruction.remove()
def testPhaseOne():
#Wait 3 seconds before loading the next image
yield viztask.waitTime(3)
#Add a critical question
critical_question = viz.addText('Would you eat this insect?',viz.SCREEN)
yes = viz.addText('Eat!',viz.SCREEN)
no = viz.addText('Do not eat!',viz.SCREEN)
critical_question.alignment(viz.ALIGN_CENTER_TOP)
critical_question.setPosition(0.5,0.9)
yes.alignment(viz.ALIGN_LEFT_TOP)
yes.setPosition(.15,.30)
no.alignment(viz.ALIGN_LEFT_TOP)
no.setPosition(.60,.30)
yes_button = viz.addButton()
yes_button.setPosition(.13,.26)
no_button = viz.addButton()
no_button.setPosition(.57,.26)
#Add model 1
quadOne = viz.addTexQuad(pos=[0.1,1.80,1.5])
texture = viz.addTexture('model.png')
#Mark the time the programme started
start_time = viz.tick()
question_data = open('experiment_data.txt','a')
def onbutton(obj,state):
#Use our starting time variable to find out how much
#time has elapsed.
elapsed_time = viz.tick() - start_time
#Create string lines to put in the data file, depending on which
#button was pushed.
if obj == yes_button:
data = 'Participant' + ' ate the insect.\t'
success.setPosition(0.5,0.7)
success_points.alignment(viz.ALIGN_CENTER_CENTER)
fail_points.alignment(viz.ALIGN_CENTER_CENTER)
fail_points.setPosition(0.5,0.45)
fail.visible(viz.ON)
fail_points.visible(viz.ON)
info_one.visible(viz.ON)
if obj == no_button:
data = 'Participant' + ' did not eat the insect.\t'
fail.alignment(viz.ALIGN_CENTER_TOP)
fail.setPosition(0.5,0.7)
success_points.setPosition(0.5,0.45)
success_points.visible(viz.ON)
#add elapsed time to data
data = data + 'Elapsed time was: ' + str(round(elapsed_time,2)) + ' seconds\n'
#Write the data to our file.
question_data.write(data)
#Flush the internal buffer.
question_data.flush()
#Remove the illustrations
quadOne.remove()
critical_question.remove()
yes_button.remove()
no_button.remove()
yes.remove()
no.remove()
viz.callback(viz.BUTTON_EVENT,onbutton)
def testPhaseTwo():
#Remove score from previous trial
success.remove()
success_points.remove()
fail.remove()
fail_points.remove()
info_one.remove()
yield viztask.waitTime( 3 )
#Add model 2
quadOne = viz.addTexQuad(pos=[0.10,1.80,1.5])
#time has elapsed.
#button was pushed.
failTwo.alignment(viz.ALIGN_CENTER_TOP)
failTwo.setPosition(0.5,0.7)
fail_pointsTwo.alignment(viz.ALIGN_CENTER_CENTER)
fail_pointsTwo.setPosition(0.5,0.45)
failTwo.visible(viz.ON)
fail_pointsTwo.visible(viz.ON)
info_two.visible(viz.ON)
successTwo.alignment(viz.ALIGN_CENTER_TOP)
successTwo.setPosition(0.5,0.7)
success_pointsTwo.alignment(viz.ALIGN_CENTER_CENTE R)
success_pointsTwo.setPosition(0.5,0.45)
successTwo.visible(viz.ON)
success_pointsTwo.visible(viz.ON)
quadOne.remove()
yes_button.remove()
no_button.remove()
yes.remove()
no.remove()
compiled exe won't save trials to AVI krimble Vizard 1 01-29-2014 12:32 PM
running experimental trials fivel_lab Vizard 3 03-18-2011 03:58 PM
