Old 06-17-2014, 07:01 AM
befl0 befl0 is offline
Problem viztracker values
I used a tracker with a vrpn. Sometimes when I do a tracker.getData() and I put it in 8 values, a mistake appears because there are " too many values to unpack" but sometimes it's working perfectly. I realy don't understand why and where I can fixed the problem. I think it's a problem of connection but I am not sure. If you can help me how to find the solution.
Old 06-19-2014, 06:52 AM
Can you post the code you're using to access the VRPN tracker and save the data to the 8 values? Also, can you post the Vizard output and error messages?
Old 07-14-2014, 09:08 AM
The code to access to the vrpn tracker is :
def bigAndSmall():
	while True:
		yield viztask.waitTime(0.0001)
		x, z, y, h, p, r, ang_der, ang_izq = tracker.getData()
And the error is : File "viztracker.py", line 56, in bigAndSmall
ValueError: too many values to unpack
check_vrpn_cookie(): VRPN Note: minor version number doesn't match: (prefer 'vrpn: ver. 07.31', got 'vrpn: ver. 07.30 0'). This is not normally a problem.
Old 07-14-2014, 11:51 AM
That error means there are more than 8 values being returned. You could save the values to a list and then extract the first 8.
data = tracker.getData()
x = data[0]
Old 07-15-2014, 02:33 AM
Thanks for this answer, of course this is the solution.
It's working perfectly
Bérengère
tracker, viztracker
Cave Collision problem TopazFrost Vizard 2 02-13-2014 03:34 PM
Vizard problem mizutani_jun Vizard 4 01-09-2011 04:39 PM
Problem with getEuler and setEuler Sandro Holzer Vizard 6 10-21-2008 06:01 AM
onkeydown list of values Cheff Vizard 2 07-02-2008 03:00 AM
problem with female animations vmonkey Vizard 1 10-07-2005 11:36 AM
