Can you post the code you're using to access the VRPN tracker and save the data to the 8 values? Also, can you post the Vizard output and error messages?
The code to access to the vrpn tracker is :
def bigAndSmall(): while True: yield viztask.waitTime(0.0001) x, z, y, h, p, r, ang_der, ang_izq = tracker.getData() x, z, y, h, p, r, ang_der, ang_izq = tracker.getData() ValueError: too many values to unpack check_vrpn_cookie(): VRPN Note: minor version number doesn't match: (prefer 'vrpn: ver. 07.31', got 'vrpn: ver. 07.30 0'). This is not normally a problem. Thanks, |
That error means there are more than 8 values being returned. You could save the values to a list and then extract the first 8.
data = tracker.getData() x = data[0] |
Thanks for this answer, of course this is the solution. It's working perfectly Bérengère |
| Tags |
| tracker, viztracker |
| Thread Tools | |
| Display Modes | Rate This Thread |
| Cave Collision problem | TopazFrost | Vizard | 2 | 02-13-2014 03:34 PM |
| Vizard problem | mizutani_jun | Vizard | 4 | 01-09-2011 04:39 PM |
| Problem with getEuler and setEuler | Sandro Holzer | Vizard | 6 | 10-21-2008 06:01 AM |
| onkeydown list of values | Cheff | Vizard | 2 | 07-02-2008 03:00 AM |
| problem with female animations | vmonkey | Vizard | 1 | 10-07-2005 11:36 AM |
