Old 01-03-2014, 02:37 AM
I think this should fix your problem:
import viztask
viz.eyeheight(0)
viz.MainView.setPosition(0,0,-4)
car1 = viz.add('box.wrl')
rim1 = viz.add('box.wrl', color = [0,0,1])
car2 = viz.add('box.wrl', color = [1,0,1])
rim2 = viz.add('box.wrl', color = [0,1,0])
action1 = vizact.spin(0,0,1,60)
action2 = vizact.moveTo([-2,0,2],speed=2.00, interpolate=vizact.easeOut)
action3 = vizact.moveTo([-2,0,2],speed=4.00, interpolate=vizact.easeOut)
def actionTime():
	rim1.addAction(action1,0)
	rim2.addAction(action1,0)
	car1.addAction(action2,0)
	car2.addAction(action3,0)
vizact.onkeydown(' ', actionTime)
def onActionEnd(e):
	if e.object is car1:
		rim1.endAction(0)
	elif e.object is car2:
		rim2.endAction(0)
viz.callback(viz.ACTION_END_EVENT,onActionEnd)
In this example, the green box (rim2) is the rim of the purple box (car2), and the blue box (rim1) is the rim of the red box (car1). The red and purple box arrive at different times at the end position, and the rotation of their rims stop accordingly. Replace the boxes with your appropriate models, and you should be good to go!
Last edited by Frank Verberne; 01-03-2014 at 02:43 AM. Reason: improved readability of code
car wheel rotation
Steering wheel mini Biom Vizard 2 06-18-2013 12:53 AM
Custom Joystick Rotation mhead10 Vizard 9 11-26-2012 01:06 PM
Changing Force-feedback on Wheel Cage Vizard 3 10-23-2010 09:37 AM
set bone rotation - cal3d munteanu24d Vizard 0 03-23-2010 05:25 AM
Unable to perform 360 rotation using vizact.spinto vijaykiran Vizard 2 09-29-2009 09:39 AM
