Old 11-10-2013, 03:56 PM
EnvisMJ EnvisMJ is offline
Introducing a rotation offset into a link
I am working in a immersive VR simulator, and I am picking up and moving objects around.
Grabbing an object is pretty easy:
grabLink = viz.link(hand,object,1)
This allows it to follow translation and orientation exactly
I can also modify the link to act in a couple different ways by modifying the link like so:
Creating a 'locked rotations' link (the grabbed object follows the translations of the hand, but it's orientation is locked at [0,0,0] exactly)
grabLink.setEuler([0,0,0])	#set the yaw, pitch and roll to zero
Create a 'z-pinned' link (the grabbed object follows rotations exactly, but the block is only able to translate in the z-axis)
yPos = object.getPosition()[1]	#y position of object
xPos = object.getPosition()[0]	#x position of object
grabLink.clampPosY([yPos,yPos],1,viz.LINK_FULL_OP)	#clamp item's vertical motion
grabLink.clampPosX([xPos,xPos],1,viz.LINK_FULL_OP)	#clamp item's lateral motion
Create a 'movement bounded' link (object can't move past the zBound point on the z-axis)
grabLink.clampPosZ([None,zBound],1,viz.LINK_FULL_OP) #clamp item's forward motion
Ok, so all that is working well and good. But now I need to 'offset' the position of the object vs. the hand with a set of offsets
rotationOffsets = [x,y,z]
Anyone know how to get this done?
grab, hand, link, offset
Link only one Axis Andy Vizard 7 06-18-2013 02:30 AM
Custom Joystick Rotation mhead10 Vizard 9 11-26-2012 12:06 PM
Unable to perform 360 rotation using vizact.spinto vijaykiran Vizard 2 09-29-2009 08:39 AM
Offset Problem Elittdogg Vizard 1 09-15-2009 06:28 AM
intersense orientation jargon Vizard 2 05-14-2005 04:55 PM
