Old 10-31-2013, 08:20 AM
Most Vizard commands are not thread safe, especially when it comes to adding/removing objects from different threads. The viz.director function mainly exists for backwards compatibility reasons, and is only intended to be used to perform non-Vizard related operations (e.g. file/socket IO).
Having said that, loading models in director threads can work. You just need to be very careful not to add/remove other models while the asynchronous operation is being performed. Additionally, the model should be added to a dummy scene when being loaded asynchronously, to avoid adding the model while the active scene is rendering.
Vizard 5 will have built-in support to load models/avatars asynchronously, and all the threading issues will be handled automatically.
random coding Saz Vizard 1 05-27-2010 05:44 PM
random speed and associated coding Saz Vizard 1 05-20-2010 04:03 AM
custom avatar random walk krimble Vizard 2 03-20-2007 03:23 AM
Random head movements VR_enthusiast Vizard 2 07-19-2006 11:59 AM
Random Seeds Vygreif Vizard 1 04-27-2006 09:21 PM
