Old 10-28-2013, 04:37 AM
apmx apmx is offline
A problem with cave
Hello,I am doing a project about car simulation,but I don't know how to link the cave view point with the car,the result should be more like sitting in the car and if the car is moving the view point should follow.
Here is my code:
import cavelib2
import math
import random
import vizshape
import vizcave
import viztracker
hangle=0
vangle=0
#Param: True = DesktopMode on
#		False = DesktopMode off
print "Initializing CaveLib"
cave = cavelib2.CaveLib(True)
import vizshape
#wiimote update code
#Speed for the wiimote movement
MOVE_SPEED = 1
#Initial values of camera angles
hangle = 0
vangle = 0
#object id's that are ignored with raycasting
drawing  = None
print "Adding a model"
#position camera in startingposition
cave_origin=cave.getOriginTracker().setPosition(0,3,0)
#cave.caveorigin.setPosition(0,2,0)
#cave.caveorigin.setEuler(90,0,0)
#adding the models
world = viz.add('road1002.OSGB')
world.setPosition(0,0,0)
world.enable(viz.LIGHTING)
truck = viz.add('truck1005.OSGB')
truck.setPosition(1,2,-8)
def WiiMove():
	global hangle
	global vangle
	elapsed = viz.elapsed()	#the amount of time elapsed
	state = cave.wiimote.getState()
	#process buttons
	if state & cave.wiimote.BUTTON_LEFT:
		#cave.caveorigin.setPosition([-MOVE_SPEED*elapsed,0,0],viz.REL_LOCAL)
		sun.setPosition([-MOVE_SPEED*elapsed,0,0],viz.REL_LOCAL)
	if state & cave.wiimote.BUTTON_RIGHT:
		#cave.caveorigin.setPosition([MOVE_SPEED*elapsed,0,0],viz.REL_LOCAL)
		sun.setPosition([MOVE_SPEED*elapsed,0,0],viz.REL_LOCAL)
	if state & cave.wiimote.BUTTON_UP:
		#cave.caveorigin.setPosition([0,0,MOVE_SPEED*elapsed],viz.REL_LOCAL)
		sun.setPosition([0,MOVE_SPEED*elapsed,0],viz.REL_LOCAL)
	if state & cave.wiimote.BUTTON_DOWN:
		#cave.caveorigin.setPosition([0,0,-MOVE_SPEED*elapsed],viz.REL_LOCAL)
		sun.setPosition([0,-MOVE_SPEED*elapsed,0],viz.REL_LOCAL)
	if state & cave.wiimote.BUTTON_1:
		cave.caveorigin.setPosition([0,-.001,0],viz.REL_LOCAL)
	if state & cave.wiimote.BUTTON_2:
		cave.caveorigin.setPosition([0,.001,0],viz.REL_LOCAL)
	hangle = hangle + 90 * cave.wiimote.getJoystick()[0] * elapsed
	cave.caveorigin.setEuler([hangle,vangle,0])
#Set input function
vizact.ontimer(0, WiiMove)
#onUpdate callback function
def onUpdate(e):
	cave.getWandPosition()
	cave.getWandQuat()
	cave.getWandMatrix()
viz.callback(viz.UPDATE_EVENT,onUpdate)
print "Setting the headlight"
#Get a handle to the main headlight and disable it
print "Setting the antialiasing factor"
viz.setMultiSample(4)
print "Start the simulation"
cave.go()
Cave GUI Rudi Vizard 3 06-14-2012 04:12 AM
Intermittent orthographic stereo projection problems AySz88 Vizard 10 02-17-2012 12:50 PM
[New here] Cave joy navigation esuna114 Vizard 2 06-11-2010 04:36 PM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 10:12 AM
