Old 09-22-2013, 11:37 AM
bzyqo bzyqo is offline
Unhappy Problem with exporting to vizard
Hello
I have currently a problem with exporting my model into vizard from 3ds max. I have baked the lights and everything looking correct but when i export to vizard as osgb this happens. How i can fix it?
Old 09-23-2013, 11:18 AM
Can you attach images of your render to texture and osg export settings?
Old 09-24-2013, 04:41 PM
Here Jeff. Before I was exporting and model come out fine. When I lightmap it this happened ;/
ID:	612   Click image for larger version
ID:	613   Click image for larger version
Old 09-25-2013, 09:44 AM
Can you also attach an image of the render to texture dialog box that shows all the settings used for the bake?
Old 09-25-2013, 10:20 AM
Here you go
Old 09-25-2013, 02:55 PM
Under Baked Material Settings try the Save Source -> Duplicate Source to Baked setting. The Light baking for Vizard tutorial shows our recommended settings.
Demystifying exporting light maps from 3ds Max to Vizard? dproeder Vizard 1 06-14-2013 01:34 PM
Vizard problem mizutani_jun Vizard 4 01-09-2011 03:39 PM
problem with exporting avatars and using them in Vizard VDong Vizard 2 02-23-2009 01:25 AM
Exporting from Maya to Vizard jfreeman Vizard 2 06-30-2005 02:14 PM
