If you're updating the viewpoint every frame, try:
viz.getFrameElapsed() * SPEED Code:
viz.elapsed() * SPEED |
Hello Jeff,
thank you very much! That solved the problem. The movement speed of the viewport is now consistent throughout all of our environments. What do you think was the problem? Is there a variation in frame draw times that depends on the current environment? If I am using viz.elapsed(), than I would not take this deviation into account, right? |
| Thread Tools | |
| Temporal delay on movement | westbyb | Vizard | 5 | 05-23-2013 06:06 PM |
| Varying rotation speed with spinTo | mape2k | Vizard | 2 | 03-22-2013 07:48 AM |
| Object + InteriaCube + Viewport problem | Gekitatsu | Vizard | 1 | 02-22-2012 10:55 AM |
| random speed and associated coding | Saz | Vizard | 1 | 05-20-2010 04:03 AM |
| Calculating Speed with sensor | durf | Vizard | 1 | 03-13-2009 10:25 AM |
