Old 06-05-2013, 10:33 AM
Andy Andy is offline
Link only one Axis
I want to link the orientation of an mySensor with a node (box).
In my example I link the node with the MainView. Furthermore, I want to link the orientation of my sensor (src) with the node (dst) too. But not all axis, like in my example, I want to link only the orientation of the Y-axis of mySensor.
Is this possible?
box = viz.add('box.wrl', pos=[0,0,0])
plan = viz.add('tut_ground.wrl')
mySensor = viz.add( 'testtrack_all.dls' )
link = viz.link(viz.MainView, box, mask=viz.LINK_POS|viz.LINK_ORI)
link.postTrans([0,0,6])
viewLinkOp = link.preMultLinkable(mySensor, target=viz.LINK_ORI)
Old 06-06-2013, 01:52 PM
Kevin Chiu Kevin Chiu is offline
Hi Andy,
Is this the effect which you want?
link = viz.link(mySensor, box, mask=viz.LINK_ORI)
link.preScale([1,0,0], target = viz.LINK_ORI_OP)
viewLink = viz.link(link, viz.MainView)
Old 06-07-2013, 01:38 AM
In part, now affected mySensor also on the MainView, that shouldnt‘ be. The orientation of mySensor (y-axis) should additional affected only on the linked box.
Any idea?
Old 06-07-2013, 03:09 PM
You can just comment out the last line of the script.
Old 06-10-2013, 02:18 AM
Yes I know but I want to link the MainView to the box node. The y orientation link of mySensor should be added like the ‘preMultLinkable’ function realize this.
Old 06-13-2013, 02:01 AM
Is there no solution for my problem?
- Filter a pre-multiply linkable operator so that only one axis of the pre-multiply-node takes an effect on the main link, like "target = viz.LINK_ORI_Y"
Old 06-13-2013, 12:33 PM
You want the position/pitch/roll of the box based on the viewpoint and the yaw of the box based on the sensor, correct?
If that's the case you could manually update the box orientation every frame in a function registered with vizact.onupdate:
link = viz.link(viz.MainView, box, mask=viz.LINK_POS)
def updateOri():
	yaw = mySensor.getEuler()[0]
	pitch = viz.MainView.getEuler()[1]
	roll = viz.MainView.getEuler()[2]
	box.setEuler([yaw,pitch,roll])
vizact.onupdate(0,updateOri)
Old 06-18-2013, 03:30 AM
Thanks it works
How to pass only 1 axis of the position signal from the source to the dest in a LINK? Zhi Vizard 2 04-04-2013 08:28 AM
How can I link MainView with HMD and a 3d node? Salvar Vizard 5 03-22-2011 09:14 PM
Link MainView to instable platform sleiN13 Vizard 2 01-10-2011 01:33 AM
Remove link and have object drop/collide? cgibb Vizard 6 03-02-2010 05:18 PM
Object rotating around world axis, not own axis tacbob Vizard 1 02-15-2007 10:12 AM
