Here are the files. (https://notredame.box.com/s/96epe30c57whx3ynq1o7)
The Racetrack.py file is the one to run. The code posted in the first post is from Car.py line 257 to 270. The code where the video work is Vizard1TestMovie.py Thanks |
Has this problem been resolved?
I am getting the same error when I try to use .addvideo, as the original poster did. It does work when I run it in Vizard4, but when I run it in Vizard5 it throws the error. Any thoughts? |
Are you running the 64-bit version of Vizard 5?
Yes, its the 64 bit version.
Do you have the 64-bit version of any necessary video codecs installed on your system?
| Thread Tools | |
| Display Modes | Rate This Thread |
| moving object forward backward | Zword | Vizard | 4 | 01-20-2011 08:21 AM |
| retrieve Object names | Geoffrey | Vizard | 11 | 12-11-2009 04:26 AM |
| Attaching sound to a moving object | GiudiceLab | Vizard | 6 | 08-21-2009 08:52 AM |
| moving and object by mouse but don't know how to stop the movement | nlfrnassimi | Vizard | 8 | 04-26-2009 07:23 AM |
| Moving view with object | Xliben | Vizard | 2 | 07-25-2005 05:36 PM |
