Old 11-21-2012, 11:48 AM
tokola tokola is offline
Thanks a lot Jeff,
it was eventually my carelessness, since I was using another class name not residing in the module
The linking works fine besides the fact that I can't get rid of the robot in the first person view, so it collides with the viewpoint and sends it to outer space! I am using the 'renderOnlyToWindows' command but it doesn't work, I assume because of the linking. If, on the other hand, I get rid of the view collision, then I can get through walls which is undesirable. What's the solution in such cases?
I have a similar problem with a hand cursor I have linked with the view in 3D space (not screen) which is offset 0.2m in front of the view and the view collides on it only when I am moving straight in one of the 4 directions. The only solution I found was to set the collisionBuffer() to zero, but then whenever I am too close to objects the cursor disappears behind them. Also collideNone() applied to the hand object doesn't resolve the problem.
Isn't there a way in both these cases to reset the collision of the object, so that it doesn't collide with the viewpoint?!? It seems such an easy fix but still...
Thanks a lot for your feedback!
'int' object not callable enkeli Vizard 8 10-22-2009 05:12 PM
'ActionData' object is not callable error Enlil Vizard 2 06-09-2008 06:03 PM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
