Old 11-02-2012, 02:50 PM
Setting the center should change the rotation point but will not affect the position of the object. You should be able to modify the center as many times as you want during the course of the script. You can use the node.getCenter command to verify the center is where you expect it to be.
It's a bit difficult to understand the problem without having an example to run. Can you create an example using Vizard's included resources that reproduces the issue and can be run directly?
joystick position nmohandes Vizard 2 01-16-2012 10:03 AM
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
Joystick Navigation Vinicius Lima Vizard 7 10-23-2007 10:42 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 10:56 AM
animating custom faces: in search of "open_mouth" morphs vr_boyko Vizard 1 09-16-2004 10:30 AM
