Old 09-11-2012, 12:49 PM
Thanks. The following code should translate the screw object along its local Y-axis:
screw = model.insertGroupBelow('Inst-1430')
screw.setPosition([0,0.1,0])
This works by inserting a node below the Inst-1430 node. If you had called getChild on the node, it would have inserted a transform above the node, which would then translate the node in the incorrect reference frame.
Make sure you only call insertGroupBelow once per sub-node, since each call will insert a new node.
Haptic touch texture coordinates yth Vizard 0 06-02-2012 04:40 AM
How do coordinates in IS900 thransform into coordinates in vizard's world jacky Vizard 1 08-11-2011 11:44 AM
child-objects in VRML-file all have the same coordinates Sven Vizard 4 06-09-2010 03:07 AM
viz.vertex coordinates lilio Vizard 6 05-16-2009 05:36 PM
Object rotating around world axis, not own axis tacbob Vizard 1 02-15-2007 10:12 AM
