Old 05-09-2011, 01:28 PM
To load a .ive model you exported use the viz.addChild command in your script:
myModel = viz.addChild('model.ive')
Using the code above the .ive file should be in the same directory as the script to be found.
Also, download the Vizard 4 Beta to use the Inspector tool. That allows you to view Vizard compatible models without running a script.
How can i import the code form a Java program to Vizard? alberto_redo Vizard 1 10-07-2010 12:18 PM
How to import the defaultdict into vizard knightgba Vizard 3 07-26-2010 01:35 PM
