Old 05-05-2011, 04:58 AM
Saz Saz is offline
Hi Jeff,
thanks for that, I've decided to use to quads and apply the textures to them instead. I'm trying to code for the textures in these two quads to both move at independent speeds in a downward motion (like lines moving down a page). In the past I've used the viz.MainView.move command but obviously that moves the whole viewpoint and so the whole quad moves (and then disappears) rather than the textures inside them.
Here is the code written so far:
#Import vizjoy module
import vizjoy
import time
import math
import vizinfo
import vizshape
viz.displaymode(1024, 512)
viz.go(viz.FULLSCREEN)
viz.mouse(viz.OFF)
vizact.ontimer(32,viz.quit) #runs file for 32 secs
subject = viz.input('What is the participant number?')
#define speed
MOVE_SPEED = 0.1041 #scalar constant for speed gain
viz.clearcolor(0.5,0.5,0.5)
viz.MainView.setPosition(0,.5,0)
#add the road texture
road = viz.add('roadld3.png')
#create a texture quad1 to add the road texture to
#and place it over ground
quad1 = viz.addTexQuad()
quad1.setScale(0.25,0.5,0.25)
quad1.setPosition(0.75,0.5,3)
quad1.setEuler(0,0,0)
quad1.texture(road)
#create a texture quad2 to add the road texture to
quad2 = viz.addTexQuad()
quad2.setScale(0.25,0.5,0.25)
quad2.setPosition(-0.75,0.5,3)
quad2.setEuler(0,0,0)
quad2.texture(road)
#move quad 1
def moveQuad1():
	viz.MainView.move(0,0,MOVE_SPEED,viz.BODY_ORI)
moveQuad1()
#call a timer every frame to check if road needs to be added
vizact.ontimer(0, moveQuad1)
Is there tutorial that explains how to assign different speeds (or speeds at all) to the textures inside quads? Any help is much appreciated
Draw line with a triangle at the end Chrissy2009 Vizard 9 08-24-2009 11:12 AM
Draw a triangle instead of a point Chrissy2009 Vizard 1 07-21-2009 09:46 AM
Draw Vector in viewpoint lookat direction Chrissy2009 Vizard 2 05-30-2009 12:50 AM
Draw Line between Points Chrissy2009 Vizard 2 05-13-2009 04:42 AM
Draw Line between Points selected by mouse Johannes Vizard 7 01-07-2005 02:50 PM
