Old 04-08-2011, 05:17 AM
nige777 nige777 is offline
Ok, well managed to get makepy to run through the Viz 4 interactive prompt (is this a valid method of doing this?) using this code:-
import win32com.client.makepy
win32com.client.makepy.ShowInfo("")
- select the MS Speech object from the list and it spits out this
Microsoft Speech Object Library
 {C866CA3A-32F7-11D2-9602-00C04F8EE628}, lcid=0, major=5, minor=4
 >>> # Use these commands in Python code to auto generate .py support
 >>> from win32com.client import gencache
 >>> gencache.EnsureModule('{C866CA3A-32F7-11D2-9602-00C04F8EE628}', 0, 5, 4)
However when I then run the speech.py script I get this error message-
  File "<string>", line 11, in <module>
  File "C:\Users\APD\Documents\Nige_PHD\Vizard_Python Development\speek.py", line 56, in <module>
    class ContextEvents(win32com.client.getevents("SAPI.SpSharedRecoContext")):
TypeError: Error when calling the metaclass bases
    cannot create 'NoneType' instances
Any ideas?? Am I doing something wrong I got it to work in Viz3 with very little problem.
Viz speech cutting off early Enlil Vizard 7 01-27-2016 05:41 AM
Speech Bubbles jassel41 Vizard 0 11-30-2009 11:12 PM
Avatar finish speech ? djdesmangles Vizard 2 02-15-2008 07:56 AM
Speech Recognition Johannes Vizard 1 05-16-2005 11:46 AM
