Old 02-22-2011, 10:48 AM
Enlil Enlil is offline
Debug error
I managed to get some code running using the Run Script option, but when I tried to debug, I got the following error (related to the Queue object)
  File "C:\Program Files (x86)\WorldViz\Vizard4\python\vizbdb.py", line 271, in start
  File "C:\Program Files (x86)\WorldViz\Vizard4\python\vizbdb.py", line 359, in message_loop
    id,data = self.wait_for_message([_DM_INITIALIZED])
  File "C:\Program Files (x86)\WorldViz\Vizard4\python\vizbdb.py", line 381, in wait_for_message
    id,data = self.message_queue.get()
AttributeError: 'Queue' object has no attribute 'get'
** Load Time: 0.01 seconds
    self.handle_message(id,data)
  File "C:\Program Files (x86)\WorldViz\Vizard4\python\vizbdb.py", line 338, in handle_message
    self.message_queue.put((id,data))
AttributeError: 'Queue' object has no attribute 'put'
Exception in thread Thread-1:
  File "C:\Program Files (x86)\WorldViz\Vizard4\bin\lib\threading.py", line 530, in __bootstrap_inner
    self.run()
  File "C:\Program Files (x86)\WorldViz\Vizard4\bin\lib\threading.py", line 483, in run
    self.__target(*self.__args, **self.__kwargs)
  File "C:\Program Files (x86)\WorldViz\Vizard4\python\vizbdb.py", line 364, in message_loop
    self.message_queue.put((None,None))
This is from a fairly large program with a lot of imports. The samples I have tried have run fine.
Christian
Old 02-22-2011, 11:09 AM
The error AttributeError: 'Queue' object has no attribute 'get' is suspicious. It seems like something is conflicting with the Queue module that is part of the standard library. Do you have a module in your script directory that is called Queue?
Old 02-23-2011, 07:13 AM
Oops, you are quite right - somebody did create a Queue class at some point. I'll have to change that.
Christian
ERROR: Failed to load .ive file turgutm Vizard 1 09-16-2010 05:16 AM
5DT glove ultra error 5dt.dls failed kabk Vizard 2 05-05-2009 12:43 PM
Howto debug a custom plugin? reedev Plug-in development 3 04-23-2009 02:16 PM
Loading morph mesh error. vEsotu Vizard 2 03-14-2009 06:29 PM
The error window that couldn't FlyingWren Vizard 2 12-02-2003 08:23 AM
