Old 12-26-2010, 10:50 PM
turgutm turgutm is offline
How to create circle like collision area
I need to create collision area like circle. And I need to get notified when object is inside and when is outside of that area.
Any suggestions?
Old 01-02-2011, 01:49 PM
You can add a function that's called every frame that checks the distance between the object and the center of the circle. Depending on the distance value you'll know whether the object is inside or outside of the circle:
import vizmat
CIRCLE_CENTER = [0,0,5]
CIRCLE_RADIUS = 2
court = viz.addChild('court.ive')
avatar = viz.addAvatar('vcc_male.cfg')
text = viz.addText('',parent=viz.SCREEN)
text.setPosition(0.3,0.8)
text.color(viz.RED)
walk = vizact.walkTo([0,0,10])
avatar.addAction(walk)
def collisionCheck():
	distance = vizmat.Distance(CIRCLE_CENTER,avatar.getPosition())
	if distance > CIRCLE_RADIUS:
		text.message('Outside circle')
		text.message('Inside circle')
vizact.ontimer(0,collisionCheck)
Old 01-04-2011, 11:19 PM
Hi, Jeff...
Thanks for reply...
It solved my problem.
Collision Exception jassel41 Vizard 2 11-09-2010 05:08 PM
Collision and avatar animation shahramy Vizard 2 10-26-2010 11:47 PM
Collision detection with specific models just alex Vizard 1 02-06-2009 11:02 AM
Collision with child nodes rubberpimple Vizard 4 09-17-2008 04:27 PM
Setting up a 'reaction area' Karthi Vizard 4 01-29-2004 04:39 PM
