Old 11-10-2010, 07:25 PM
Renato Lima Renato Lima is offline
Question Is it possible to have make my shapes have black borders?
I have a series of shapes either added from a 3ds file or generated. Can I have them display a black line over each of their wirelines? (a black contour)?
Old 11-10-2010, 07:57 PM
Here is a sample script showing how to draw a black line over the wireframe of a model:
viz.clearcolor(viz.GRAY)
frag_black = """
	void main()
	gl_FragColor = vec4(0,0,0,1);
shader_black = viz.addShader(frag=frag_black)
def addWireOutline(node):
	node.wire = model.clone(parent=node)
	node.wire.polyMode(viz.POLY_WIRE,op=viz.OP_OVERRIDE|viz.OP_ROOT)
	node.wire.zoffset(op=viz.OP_OVERRIDE|viz.OP_ROOT)
	node.wire.apply(shader_black,op=viz.OP_OVERRIDE|viz.OP_ROOT)
model = viz.addChild('ball.wrl',pos=(0,1.8,2))
addWireOutline(model)
model.addAction(vizact.spin(0,1,0,90))
vizact.onkeydown(' ',model.wire.visible,viz.TOGGLE)
Let me know if I misunderstood what you were asking for, or if anything is unclear.
Old 11-13-2010, 09:35 AM
Thank you very much.
Show Physics Shapes bloswald Vizard 3 04-07-2010 04:16 PM
How to make screen black? Josh Vizard 1 04-02-2010 01:30 PM
How to make character animation sequence wchoi Vizard 3 01-22-2010 09:35 AM
cinematic fade to black? billjarrold Vizard 4 12-23-2009 12:09 PM
black outs enkeli Vizard 4 05-09-2006 01:05 PM
