Old 09-21-2010, 12:53 PM
Philippe Philippe is offline
limiting object rotation
Is there a method enabling to limit the range of rotation of a tracking device (Euler) relatively to the orientation of another tracking device (in my case, I have a gun which orientation's follows the glove position, and I would like to limit the orientation of the gun so that it cannot point backwards but only forwards - i.e. limiting the yaw of the gun to a range from -90 degrees to +90 degrees relatively to the current direction of the HMD).
Is there a simple way to do this?
In order words, I would like not to enable the gun to point backwards (this is some workaround solution: due to some tracking issues, it happens that the gun suddenly "flips back" and stays pointing backwards even when the glove stays more or less in the north direction ; I would like to have the glove never identified as pointing south).
Philippe.
Philippe
Unable to perform 360 rotation using vizact.spinto vijaykiran Vizard 2 09-29-2009 09:39 AM
Object rotation Andrey Vizard 4 06-13-2007 03:49 PM
Child Object Rotation paulgoldberg Vizard 5 09-05-2006 12:33 PM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
