Old 07-23-2010, 09:07 AM
nige777 nige777 is offline
Ok, I'm getting somewhere here I think. Here's what I am using now:
def ChooseFile():
	"""You can find documentation for CreateFileDialog at the following site:
		http://aspn.activestate.com/ASPN/docs/ActivePython/2.5/pywin32/win32ui__CreateFileDialog_meth.html"""
	parent = win32ui.CreateWindowFromHandle(viz.window.getHandle())
	dlg = win32ui.CreateFileDialog(1,'','',0,'',parent)
	if dlg.DoModal() == win32con.IDOK:
		file = dlg.GetFileName()
		inFileName  = dlg.GetPathName()
		print file
		print inFileName
- Thanks farshi
However, what I would really like to do is open the selected file, so I tried adding:
		FILE = open(file, 'r')
		for line in FILE:
			print line
- but all I get is
ÐÏࡱ
So my question is - what am I doing wrong here, I just want a participant to be able to select a file which is then read in / parsed into useful chunks of data.
Also when exiting winviz after running this I get a - "winviz.exe has encountered a problem and needs to close. We are sorry for the inconvenience." from windoze
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 02:20 AM
problems with output to a text file within executable Saz Vizard 1 07-01-2009 12:01 PM
Problem generating exe file Anfo Vizard 1 11-17-2008 05:21 PM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 03:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 10:44 AM
