Old 07-07-2010, 08:05 AM
Enlil Enlil is offline
Head mesh indirection
I am trying to make an avatar head disappear. I would like to use the 'head_mesh' that is defined to allow setFace to make a head invisible, but an avatar.visible(viz.OFF, 'head_mesh') does not work. I also tried getting the meshes from getMeshList(), but that seems to return strings. How do I access the mesh to make it invisible?
Christian
Old 07-08-2010, 05:57 AM
The following will hide the head mesh. The first name in the list is for the head mesh.
avatar = viz.add('vcc_male.cfg', pos=[0,0,5], euler=[180,0,0])
list = avatar.getMeshList()
avatar.visible(0,list[0])
Old 07-08-2010, 09:11 AM
Thanks!
Christian
View attached to avatar head -> artifacts of head model! Josh Vizard 2 04-16-2010 07:35 AM
Problems with getting head bone rotation right Enlil Vizard 2 02-13-2009 11:24 AM
Awkward neck/shoulder connection when adding custom head to vcc model. vEsotu Vizard 5 10-09-2008 06:07 PM
problems adding a custom morph head to a custom body Greenwu Vizard 1 07-27-2006 11:32 AM
How to simply texture an avatar's head with a jpeg graphic? vr_boyko Vizard 3 10-26-2004 11:44 AM
