just ordinary 32bit.
just like you... thanx, that at least lets me know its possible
Vizard should run fine on both 32-bit and 64-bit system. Have downloaded and installed the correct drivers for you graphics card?
Yes I have.
I have solved the problem. It is because of my video card setting(s) ( ATI catalyst ) (but not bad drivers or something, apparantly something is not supported by Vizard) When dropping all to lowest of the low setting, it works. Ill try to figure out which option is the nasty .... and, if anyone is interested (??) post that. thanx for the replies |
| Thread Tools | |
| Bluetooth speaker crashes Vizard? | GiudiceLab | Vizard | 2 | 06-09-2009 05:56 PM |
| just downloaded Vizard Lite - crashes upon startup... | bernie | Vizard | 6 | 11-23-2008 10:56 AM |
| winvix.exe crashes | mjabon | Vizard | 1 | 08-27-2007 10:15 AM |
| Help with Vizard crashes... | vanier | Vizard | 1 | 01-12-2006 03:08 PM |
| Vizard Crashes: causes are hard to determine, possible problem with the viz code | vr_boyko | Vizard | 1 | 01-07-2005 11:52 AM |
