Old 06-28-2010, 01:27 AM
znchb znchb is offline
Is your Win7 runs the 64-bit or 32-bit operation system?
I don't know whether there is any conflict with 64-bit system.
But Mine is 32-bit, install the Vizard 3.0 and run program, that's it.
Old 06-28-2010, 02:33 AM
Nevyle Nevyle is offline
just ordinary 32bit.
just like you...
thanx, that at least lets me know its possible
Old 06-28-2010, 10:35 AM
Vizard should run fine on both 32-bit and 64-bit system. Have downloaded and installed the correct drivers for you graphics card?
Old 06-28-2010, 12:21 PM
Yes I have.
I have solved the problem.
It is because of my video card setting(s) ( ATI catalyst )
(but not bad drivers or something, apparantly something is not supported by Vizard)
When dropping all to lowest of the low setting, it works.
Ill try to figure out which option is the nasty ....
and, if anyone is interested (??) post that.
thanx for the replies
Bluetooth speaker crashes Vizard? GiudiceLab Vizard 2 06-09-2009 05:56 PM
just downloaded Vizard Lite - crashes upon startup... bernie Vizard 6 11-23-2008 10:56 AM
winvix.exe crashes mjabon Vizard 1 08-27-2007 10:15 AM
Help with Vizard crashes... vanier Vizard 1 01-12-2006 03:08 PM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 11:52 AM
