Anyone ?? plz ??
I need to build a thesis project using this software, so It would be nice to get it to work... ![]() Again, I open de program, open de tutorial, press run, it does something: ************************************************** **************************** ** Loading tutorial.py ************************************************** **************************** Loading File: vcc_male.cfg Loading File: room.wrl Loading File: light.WRL ** Load Time: 1.95 seconds ..... then it crashes..... are there some settings I need to set maybe ?? thanx anyways. regards Nev |
Is your Win7 runs the 64-bit or 32-bit operation system?
I don't know whether there is any conflict with 64-bit system. But Mine is 32-bit, install the Vizard 3.0 and run program, that's it. |
just ordinary 32bit.
just like you... thanx, that at least lets me know its possible
Vizard should run fine on both 32-bit and 64-bit system. Have downloaded and installed the correct drivers for you graphics card?
Yes I have.
I have solved the problem. It is because of my video card setting(s) ( ATI catalyst ) (but not bad drivers or something, apparantly something is not supported by Vizard) When dropping all to lowest of the low setting, it works. Ill try to figure out which option is the nasty .... and, if anyone is interested (??) post that. thanx for the replies |
| Thread Tools | |
| Bluetooth speaker crashes Vizard? | GiudiceLab | Vizard | 2 | 06-09-2009 04:56 PM |
| just downloaded Vizard Lite - crashes upon startup... | bernie | Vizard | 6 | 11-23-2008 09:56 AM |
| winvix.exe crashes | mjabon | Vizard | 1 | 08-27-2007 09:15 AM |
| Help with Vizard crashes... | vanier | Vizard | 1 | 01-12-2006 02:08 PM |
| Vizard Crashes: causes are hard to determine, possible problem with the viz code | vr_boyko | Vizard | 1 | 01-07-2005 10:52 AM |
