Old 04-07-2010, 03:16 PM
You would have to adjust the position of the box or sphere used to visualize the collision area.
In the following example the avatar origin is at the bottom of his feet so the box does appear to be in the correct position. Hit the spacebar to adjust the position of the box.
viz.clearcolor(viz.SKYBLUE)
logo = viz.add('logo.wrl',pos=[-1,1.5,6],euler=[0,0,30])
logo.collideBox()
logo.add('box.wrl',alpha=.2,scale=logo.getBoundingBox(viz.REL_LOCAL).size)
avatar = viz.add('vcc_male.cfg',pos=[1,0,6],euler=[180,0,0])
avatar.collideBox()
box = avatar.add('box.wrl',alpha=.2,scale=avatar.getBoundingBox(viz.REL_LOCAL).size)
vizact.onkeydown(' ',box.setPosition,[0,.9,0])
import vizcam
viz.cam.setHandler(vizcam.PivotNavigate(center=[0,1,6],distance=5))
The collideMesh area is the same as the object itself so it is not necessary to build anything to visualize it.
Show flight path of balls snoopy78 Vizard 1 08-28-2009 02:57 PM
physics engine exception ad_astra Vizard 3 03-25-2009 11:31 AM
Physics and Haptics jalvarez Vizard 3 07-16-2008 03:03 PM
another physics question adimov Vizard 1 07-22-2004 03:56 PM
Physics engine question adimov Vizard 2 07-22-2004 12:33 PM
