Old 12-07-2009, 01:32 PM
nitao nitao is offline
question about IS-900 wand
I am new to Vizard, and our lab is starting using Vizard for a project. I have trouble with getting the IS-900 wand work. I followed the tutorial and wrote a small program. The tracker works, but I cannot retrieve the data from the joystick or buttons on the wand. The script is as follows:
#Add environment
viz.add('gallery.ive')
#Add the intersense plugin
tracker1 = viz.add('intersense.dls')
tracker2 = viz.add('intersense.dls')
# This function will grab the tracker data and update the viewpoint
def UpdateView():
#Get tracker euler rotation
yaw,pitch,roll = tracker2.getEuler()
#Only rotate the yaw of the body orientation
viz.MainView.setEuler([yaw,0,0],viz.BODY_ORI)
#Call UpdateView function every frame
vizact.ontimer(0,UpdateView)
#The current value of the analog joystick of the IS-900 is located at index 8,9.
#Index 8 represents the X-axis of the joystick and ranges between -1 to 1.
#Index 9 represents the Y-axis of the joystick and ranges between -1 to 1.
data = tracker2.getData()
print data[8], data[9]
state = int(tracker2.getData() [7])
if state & 1:
print 'Button 1 is down'
#Rest tracker when 'r' key is pressed
vizact.onkeydown('r',tracker1.reset)
vizact.onkeydown('r',tracker2.reset)
tracker1 is the head tracker connected to the station 1, and the wand station 2.
Can anyone tell me what's wrong, either with the code or the hardware setup?
Tao
CAVE, navigation, tracked wand, coordinate systems JimC Vizard 6 10-09-2009 01:43 PM
General question and question regarding arrays dan12345 Vizard 1 01-15-2008 11:15 AM
question about yaw, pitch, roll TunTun Vizard 2 05-23-2007 01:46 PM
to rephrase my question... shai Vizard 2 10-27-2004 11:55 AM
Lots of Question Karthi Vizard 4 02-20-2004 07:42 PM
