Old 05-11-2009, 05:32 PM
Interesting goal. I whipped up a bit of code that orbits the sphere by telling the sphere to "lookat" the intersection point, then rotating the sphere the initial offset amount.
The code is not quite right yet because sustained clicking on the same point rolls the sphere around that point. Maybe somebody knows whats wrong?
import vizmat
import vizshape
viz.mouse.setOverride(viz.ON)
node = vizshape.addSphere(pos=[0, 1.8, 3])
node.texture(viz.add('image2.jpg'))
rotation = None
def onGrab():
	global rotation
	intersectionItem = viz.pick(1)
	if intersectionItem.valid:
		src_ori = vizmat.Quat(node.getQuat(viz.ABS_GLOBAL))
		node.lookat(intersectionItem.point, viz.ABS_GLOBAL)
		dst_ori = vizmat.Quat(node.getQuat(viz.ABS_GLOBAL))
		#D = O * S so O = D * 1/S
		rotation =  src_ori * dst_ori.inverse()
vizact.onmousedown(viz.MOUSEBUTTON_LEFT, onGrab)
def moveSphere():
	if rotation:
			node.lookat(intersectionItem.point)
			node.setQuat(rotation, viz.ABS_LOCAL)
vizact.onupdate(viz.PRIORITY_DEFAULT, moveSphere)
def endGrab():
	global rotation
	rotation = None
vizact.onmouseup(viz.MOUSEBUTTON_LEFT, endGrab)
reseting an object durf Vizard 3 03-18-2009 12:48 AM
Object rotating around world axis, not own axis tacbob Vizard 1 02-15-2007 10:12 AM
Child Object Rotation paulgoldberg Vizard 5 09-05-2006 12:33 PM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
