Old 08-27-2021, 11:24 AM
One way to do this is to first create a group tracker in vizconnect that will contain the modified tracking data without roll. Next, in the avatar animator set the avatar head to move with this group tracker. Then in a callback function, which could be in the postInit or the application script, set the group tracker's position,yaw, and pitch using data coming from the Oculus tracker. Here's an example function:
def postInit():
"""Add any code here which should be called after all of the initialization of this configuration is complete.
Returned values can be obtained by calling getPostInitResult for this file's vizconnect.Configuration instance."""
Group tracker need to be added to vizconnect and used in animator
groupTracker = vizconnect.getRawTracker('headTrackerGroup')
steamHeadTracker = vizconnect.getRawTracker('head_tracker')
def onUpdate():
pos = oculusHeadTracker.getPosition(viz.ABS_GLOBAL)
ori = oculusHeadTracker.getEuler(viz.ABS_GLOBAL)
Set roll to 0
ori = [ori[0], ori[1], 0]
groupTracker.setPosition(pos, viz.ABS_GLOBAL)
groupTracker.setEuler(ori, viz.ABS_GLOBAL)
vizact.onupdate(vizconnect.PRIORITY_ANIMATOR+1, onUpdate)
return None
combining trackers, motion sickness, mouse & keyboard walking, oculus dk2
Walking is reversed in X and Z axes with motion capture. amir Vizard 2 07-31-2018 07:18 PM
motion tracker changes Vizard timing jelly Vizard 4 06-13-2016 11:34 AM
how to reduce motion sickness with Oculus rift+logitech driving force hzhao Vizard 2 09-23-2015 06:34 AM
Intermittent orthographic stereo projection problems AySz88 Vizard 10 02-17-2012 12:50 PM
