Old 04-22-2016, 09:14 AM
jelly jelly is offline
Thank you very much!
It worked now, though I am not sure what did the trick! I simplified it and it now looks like this:
import viz															#Needed to generate a world.
import viztask														#Needed to control the experiment structure.
viz.mouse.setVisible(viz.OFF) 										#Stops the mouse appearing on the screen.
viz.mouse.setOverride(viz.ON)										#Stops Vizard navigation using the mouse.
viz.clearcolor(viz.BLACK)
#Set the start position:
startPos = [-6.4,0,-8]
### Add all the resources. ###############
maze1 = viz.add('Objects/Maze_1.dae')
maze1.visible(viz.OFF)
#Add a sky with an environment map.
env = viz.add(viz.ENVIRONMENT_MAP,'sky.jpg')
dome = viz.add('skydome.dlc')
dome.texture(env)
view = viz.MainView
view.eyeheight(1.4)
view.setPosition(startPos)
view.collision(viz.ON)
viz.collisionbuffer(.8)
##Animation path
pathMaze1 = viz.addAnimationPath()
#Add control points to the path, along with their time stamp.
pathMaze1.addControlPoint(2, pos=startPos,euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(4, pos=startPos,euler=(90,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(6, pos=(0,0,-8),euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(8, pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
#Duation of animation
pathMaze1Duration = pathMaze1.getDuration()
def animation():
	link = viz.link(pathMaze1,view)
	pathMaze1.play()
	yield viztask.waitTime(pathMaze1Duration)
	pathMaze1.reset()
def maze1trial():
	print 'now'
	print view.getPosition(mode = viz.ABS_PARENT)
	maze1.visible(viz.ON)
	yield animation()
def masterFunction():
	for x in range(4):
		yield maze1trial()
viztask.schedule(masterFunction())
problem with path animation jelly Vizard 5 04-20-2016 06:15 AM
Road Animation Path vserchi Vizard 4 11-12-2015 09:29 AM
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 04:23 PM
speed on animation path whj Vizard 8 11-17-2008 07:41 PM
another bezier animation problem masaki Vizard 1 01-24-2008 02:29 PM
