Old 04-16-2016, 11:42 AM
jelly jelly is offline
problem with path animation
Hello!
I want to run a function 4 times. The function entails that the viewpoint is being animated as to look as it is moving through a maze. The problem is that, while it always loads the function 4 times, the animation only works the first time, after which is stops at the position of the end of the animation. It's as if the viewpoint does not get updated back to its initial setting.
I would be extremely grateful for any help or pointers, because I tried everything I could think of and it is just trial-and-error!
import viz															#Needed to generate a world.
import viztask														#Needed to control the experiment structure.
viz.mouse.setVisible(viz.OFF) 										#Stops the mouse appearing on the screen.
viz.mouse.setOverride(viz.ON)										#Stops Vizard navigation using the mouse.
viz.clearcolor(viz.BLACK)
#Set the start position:
startPos = [-6.4,0,-8]
### Add all the resources. ###############
maze1 = viz.add('Objects/Maze_1.dae')
#maze1.visible(viz.ON)
subwindow = viz.addWindow()
view = viz.addView()
view.eyeheight(1.4)
view.setPosition(startPos)
view.collision(viz.ON)
viz.collisionbuffer(.8)
subwindow.setView( view )
subwindow.setSize( 0.4,0.4 )
subwindow.setPosition(0.3,0.7) #(0,1)
subwindow.visible( viz.ON )
##Animation path
pathMaze1 = viz.addAnimationPath()
#Add control points to the path, along with their time stamp.
pathMaze1.addControlPoint(0,pos=(-6.4,0,-8),euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(2,pos=(-6.4,0,-8),euler=(90,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(4,pos=(0,0,-8),euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(8,pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
#Duation of animation
pathMaze1Duration = pathMaze1.getDuration()
#Loop the path in a swinging fashion (point A to point B to point A, etc.).
pathMaze1.setLoopMode(viz.OFF)
def maze1():
	print 'now'
	view.setPosition(-6.4,0,-8)
	link = viz.link(pathMaze1,view)
	yield viztask.waitTime(2)
	pathMaze1.play()
	yield viztask.waitTime(pathMaze1Duration)
def masterFunction():
	for x in range(4):
		yield maze1()
viztask.schedule(masterFunction())
Old 04-18-2016, 02:52 AM
I noticed that it's not good to have a function with the same name is an object "maze1" so I cahnged the fucntion name to "maze1trial". This, however still has not solved my problem. I wonder why the viewpoint does not reset to the start position, or why the animation does not play again, respectively? I played around with the viewpoint and thought it may be because of the link, so within the trial, at the very end, I am also unlinking, just to be sure. Still did not solve the issue. I would just like the maze objhect to lead and then the viewpoint animation to be played 4 times (as in repeating the animation 4 times, one after the other).
It now looks like this:
maze1.visible(viz.OFF)
#Add a sky with an environment map.
env = viz.add(viz.ENVIRONMENT_MAP,'sky.jpg')
dome = viz.add('skydome.dlc')
dome.texture(env)
view = viz.MainView
view.eyeheight(1.4)
viewNode = viz.addGroup()
viewLink = viz.link( viewNode, viz.MainView)
viewNode.setPosition([-6.4,0,-8])
##Animation path
def maze1trial():
	print 'now'
	viewNode.setPosition(-6.4,0,-8)
	link = viz.link(pathMaze1,viewNode)
	yield pathMaze1.play()
	link.remove
	for x in range(4):
		yield maze1trial()
Old 04-18-2016, 02:53 AM
I would really appreciate your help!
Old 04-18-2016, 06:01 AM
Make sure you reset the path at the beginning of each trial:
pathMaze1.reset()
Old 04-18-2016, 07:18 AM
Smile
Thank you so much, this did the trick and it now works perfectly!!
Old 04-20-2016, 06:15 AM
Exclamation Help again, coordinates not reset
Dear Jeff,
I am sorry, but I am still having problems. To simplify the issue I will explain the first problem I am having, as (once solved) it may solve the others as well.
The problem is that once the trial and the animation run once, the other times they run, the coordinates are reset. To find out what happens I added two lines to find out the cooridnates (red below), at those points where I believe I should get the starting and end positions. But the output gives me this:
now
[-6.400000095367432, 0.0, -8.0]
[0.0, 1.399999976158142, 5.0]
now
[0.0, 0.0, 5.0]
[0.0, 0.0, 5.0]
now
[0.0, 0.0, 5.0]
[0.0, 0.0, 5.0]
now
[0.0, 0.0, 5.0]
[0.0, 0.0, 5.0]
Only the very fist line is correct, since that is the starting position. What happens with the coordinates for the animation and the viewpoint during the other 3 trials?. I would be so grateful for your help!
I have updated the code below.
dome.texture(env)
view = viz.MainView
view.eyeheight(1.4)
##Animation path
def maze1trial():
	print 'now'
	print view.getPosition(mode = viz.ABS_PARENT)
	pathMaze1.reset()
	link.remove
	for x in range(4):
		yield maze1trial()
How to create Animation Path Abood Karkar Vizard 2 01-27-2016 05:03 PM
Road Animation Path vserchi Vizard 4 11-12-2015 09:29 AM
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 04:23 PM
speed on animation path whj Vizard 8 11-17-2008 07:41 PM
