Old 06-13-2014, 11:46 AM
JB_HP_Viz JB_HP_Viz is offline
Vizconnect SpaceGrip problem
I'm trying to use the Laseraid SpaceGrips as an Input in the Vizconnect interface but it doesn't look like it is working correctly. The Status shows a green light like it is working but this shows whether the SpaceGrips are connected to my computer or not.
I noticed that the SpaceGrips are connecting via Port 5 (COMM5) and it looks like the default is Port 1. There doesn't seem to be any way to change the Port # in Vizconnect.
I did use the Example code you had in the Reference Section under Gaming Devices -> Laseraid SpaceGrips and the SpaceGrips work fine using the Example Code.
Checking to see if there is anything I can do to get the SpaceGrips working in Vizconnect?
thank you
John
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 09:45 AM
Cave Collision problem TopazFrost Vizard 2 02-13-2014 02:34 PM
Vizard problem mizutani_jun Vizard 4 01-09-2011 03:39 PM
Vertex shader performance problem Joran Vizard 2 11-17-2008 01:29 AM
