Old 03-24-2014, 08:56 AM
fivel_lab fivel_lab is offline
Thanks again, Jeff.
We're currently using v1.2 but I've tried all of the above with v1.0 and get the same problem.
I'm not sure whether your method will work but we will try it out.
Stupid question: your suggestion implies that both the head and foot needs to be visible to (tracked by) FAAST -- am I reading that correctly? We were assuming it didn't matter which points were visible to FAAST because the error was present whether or not the feet were being tracked. Also, if this is the way it works, would it help to set FAAST to track only the upper body?
cal3d skeleton exporter error pwsnow Vizard 0 07-23-2013 09:15 AM
Kinect auto selection of skeleton victorqx Vizard 0 05-29-2012 08:30 AM
Head Height Plymouth Vizard 5 02-12-2007 10:38 AM
female skeleton CSF file needed to export to CAF format vmonkey Vizard 1 10-04-2005 10:15 AM
Constraining Height nickyee Vizard 7 01-18-2005 01:46 PM
