Old 06-13-2013, 10:33 AM
Perhaps you can add a cube that is sized to match where the marks are placed. Then you can get which face of the cube and position of the cube using viz.pick. You could then perform some calculations to normalize the pick location to match texture coordinates. In the following example the cube is not visible because the viewpoint is inside it and back faces are not rendered by default:
import vizshape
env = viz.addEnvironmentMap('sky.jpg')
sky = viz.addCustomNode('skydome.dlc')
sky.texture(env)
vizshape.addGrid()
cube = vizshape.addCube(size=80,splitFaces=True)
def getPickInfo():
	info = viz.pick(info=True)
	print 'name',info.name
	print 'point',info.point
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,getPickInfo)
Texture Coordinates in a Cube Map mshukun Vizard 2 05-10-2013 12:31 PM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 06:17 AM
How do coordinates in IS900 thransform into coordinates in vizard's world jacky Vizard 1 08-11-2011 10:44 AM
viz.vertex coordinates lilio Vizard 6 05-16-2009 04:36 PM
Inertia Cube bstankie Vizard 1 03-24-2003 11:00 AM
