We are using a CyberGlove Systems CyberTouch glove.
Ok so I uninstalled everything again to clean everything up, there were 32bit and 64bit versions of the SDKs installed. I use the cyberglove.dle extension now, and I installed the 64bit glove drivers from the CD. I placed the SDK DLLs from C:\Program Files\CyberGlove Systems\VirtualHand SDK\lib\winnt_386\Release into the same directory where my .py file is, but now I again get the error ** ERROR: Failed to load plug-in: 'CyberGlove.dle' But why? DCU is running, glove is shown and works perfectly fine, also the vibrator test. Just in vizard it does not work?! Do I have to install the 32bit SDK again? But then that is version 2.10, and now I have 3.1.1. Or maybe I just placed the wrong DLLs in my script folder or so? Quote:
| Failed to load jpeg | mhead10 | Vizard | 2 | 03-20-2012 12:53 PM |
| ERROR: Failed to load .ive file | turgutm | Vizard | 1 | 09-16-2010 06:16 AM |
| Failed to load wav file | BrynJ | Vizard | 1 | 04-24-2008 10:35 AM |
| intersense: Failed to set control word on \\.\COM1 | OueOue | Precision Position Tracker (PPT) | 2 | 01-18-2007 01:51 PM |
| Could not find plugin to load objects... | halley | Vizard | 1 | 05-30-2006 12:01 PM |
