Old 08-04-2009, 09:29 AM
durf durf is offline
removing multiple objects
I cannot figure out how to remove or delete multiple objects that have been created this way:
	def balls():
		ball = ballOriginal.copy()
		ball.scale(.5,.5,.5)
		ball.collideSphere()
		ball.setPosition([0,20,0])
	vizact.ontimer2(0,200,balls)
How can I remove all 200 of those balls?
Old 08-04-2009, 04:55 PM
You should save each object you create into a global list. Then you can periodically go through the list and remove the objects.
Old 08-04-2009, 05:01 PM
Is there a good example of this to follow?
Old 08-04-2009, 05:09 PM
I'm not sure there is an example that does exactly what you want, but the Duck Court example script that comes with Vizard shows how to save objects into a global list so they can be referenced later.
Old 08-05-2009, 08:31 AM
ballList = []
def balls():
     ballList.append(ball)
So I added a global list... how do you "periodically go through the list and remove the objects"? I tried ballList.remove() and that didn't work.
Old 08-05-2009, 10:02 AM
GiudiceLab GiudiceLab is offline
I'm not sure if I understand exactly what you want to do, but if you first make the global list and then want to take all the balls out of it, you could:
for row in range(len(ballList)):
		ballList[row].remove()
which will cycle through your list and remove each item.
Or, you could just erase your list by re-initializing it (I think):
ballList = []
Old 08-05-2009, 10:13 AM
Ok I will give that a try later... thanks for the feedback
Old 08-05-2009, 10:15 AM
Great I think it worked.
multiple objects durf Vizard 1 04-10-2009 02:42 PM
Moving multiple objects with ppt durf Vizard 1 02-10-2009 04:03 PM
Problems with making multiple objects from one .wrl? mjabon Vizard 3 07-10-2007 02:23 PM
