Old 05-09-2009, 08:36 AM
sebzim4500 sebzim4500 is offline
Unhappy Big Problem
when I try to run a script which requires some kind of plugin It always says
** ERROR: Failed to load plug-in: 'hd2.dlm'
(or whatever the plugin is that is required)
I use windows vista home premium. Any suggestions.
Old 05-11-2009, 09:43 AM
If this is happening with all plugins, then Vizard might not have been installed correctly on your computer. Make sure the plugins are located in the Vizard/plug-ins directory.
Also, keep in mind that some plugins depend on 3rd party software in order to load correctly. For example, the hd2.dlm plugin requires OpenHaptics to be installed.
Old 05-14-2009, 02:47 AM
Thanks for the help, I reinstalled the openhaptics toolkit and now it works fine.
export problem bazelaisr Vizard 2 05-28-2008 10:19 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
