Old 05-08-2009, 12:39 PM
durf durf is offline
run multiple actions simultaneously
I cannot seem to figure out how to run actions simultaneously. Everything I try does one before another. Is there a way to make two things happen at once.
resize = vizact.size(.15,.15,.15,30,viz.time)
move = vizact.goto(0,14,-20,2)
any way to make these happen at the same time?
Old 05-08-2009, 01:17 PM
Have a look at the documentation for node.addAction and node.runAction. Both these commands have an optional pool parameter. Adding actions to different pools allows you to run them simultaneously.
Another way to run actions in parallel is to use the vizact.parallel command, also in the docs.
multiple objects durf Vizard 1 04-10-2009 02:42 PM
multiple shadows using projector theuberk Vizard 13 02-24-2009 03:56 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
Speech during actions zoltantoth Vizard 2 05-02-2007 04:11 PM
Weird lagging/choppiness when avatars perform actions vjonshih Vizard 8 11-30-2004 05:08 PM
