Old 05-05-2009, 03:49 AM
Penguin Penguin is offline
rotate object in relation of sth. else
Probably a simple question:
How do I rotate an object (node3d) in relation to another objects local coordinate system?
For instance, I want to relatively rotate object1 by 1 degree in relation to the z-axis of object2s local coordinate system (roll of 1 degree according to object2).
In another example I want to relatively rotate object1 by 1 degree in relation to the main view (roll of 1 degree according to main view).
Old 05-05-2009, 01:47 PM
You can use the matrix.preEuler methods to rotate objects relative to arbitrary coordinate frames. Here is how you would roll object1 relative to object2's coordinate frame:
m = object2.getMatrix()
m.preEuler(0,0,1)
object1.setQuat(m.getQuat())
You would use similar code to perform the rotation relative to the viewpoint by retrieving the matrix from the viz.MainView object.
Let me know if I misunderstood your question or you need more specific examples.
Old 05-06-2009, 12:45 AM
This is not exactly what I meant.
For illustrating I attached some screen shots:
Left picture:
Start position. object1 = blue torus, object2 = white torus)
Middle picture:
Your end position. Your code seems to copy the complete orientation of object2 to object1
Right picture:
Desired end position. I want to rotate object1 according to the orientation of object2. Kinda object1.setEuler([0,0,45],viz.REL_LOCAL_of_object2)
ID:	316   Click image for larger version
ID:	317   Click image for larger version
Old 05-06-2009, 11:37 AM
Ok, it sounds like you want a hierarchical relationship between object1 and object2. In this case you would simply add object1 as a child to object2. When object2 is rotated, object1 will automatically rotate in object2's reference frame. If for some reason you don't want a to use a hierarchical relationship, then here is some code to manually compute the matrix:
euler = viz.Matrix.euler(0,0,roll)
m1 = object1.getMatrix()
m2 = object2.getMatrix()
diff = m1 * m2.inverse()
m2new = euler * m2
object2.setQuat(m2new.getQuat())
object1.setMatrix(diff * m2new)
Old 05-06-2009, 01:05 PM
Me gusta el code. Porque yo tengo code similar, pero esto code es mas fácil.
También, Penguin usted puede utilizar un objeto Link para esto, si no te gusta hierarchical.
Old 05-06-2009, 01:16 PM
Vous êtes fou mec. J'ai comme vous, mais vous êtes fou.
Old 05-11-2009, 09:54 AM
Thank you, the code works best for me! I only did some minor changes: translating to origin before rotating:
m1.setTrans(0,0,0)
m2.setTrans(0,0,0)
m2new = euler * m2
m1new = diff * m2new
m1new.setTrans(object1.getPosition(viz.ABS_GLOBAL))
object1.setMatrix(m1new)
how to pick up the object, move and rotate using mouse nasr Vizard 5 05-05-2009 04:11 AM
reseting an object durf Vizard 3 03-18-2009 12:48 AM
Child Object Rotation paulgoldberg Vizard 5 09-05-2006 12:33 PM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
