Old 04-28-2009, 03:36 PM
envisC envisC is offline
Four Wall Cave on One Computer
We are having trouble setting up our four wall cave to run on one computer with a NVIDIA Quadro Plex. Our only successful attempt so far has been creating sub windows, and then dragging the main window to stretch across the four screens.
Any suggestions on how to properly set up a four wall cave using just one computer? Thanks!
Old 04-28-2009, 06:02 PM
It's not possible to set up a four wall cave on one machine using the Quadro plex. Vizard can talk to one GPU but the Quadro Plex has multiple GPU's.
If, for example, you had a graphics card with one GPU and two video outputs then you could set up a two walled cave with that. If the models in your scene are simple the framerate could be fine
However, I don't know of a card with one GPU and four video outputs.
orthographic projection in a head-tracked cave environment michaelrepucci Vizard 5 12-14-2011 11:29 AM
Problems implementing Vizard in a CAVE with Shutter Glasses shivanangel Vizard 7 05-20-2009 12:47 PM
Four-wall CAVE using two PCs dtidrow Vizard 5 03-24-2009 03:51 PM
navigation in cave environment Andy Vizard 4 03-28-2008 02:32 AM
How can I find the network address of this computer? Vbents Vizard 1 08-02-2006 10:46 AM
