Old 03-11-2009, 09:51 PM
nlfrnassimi nlfrnassimi is offline
View
I have tried to link my view to my avatar and make it first point of view. I have assigned r key to make avatar and view go to a certain point and also created another view to be able to change my view. I have tried to look side, up and down by pressing certain keys but they don't work properly and another problem is that my animated path (r key ) doesn't work now.
Please take a look at my code. and tell me what are the mistakes that I have made.
viz.add('tut_ground.wrl')
view = viz.MainView
character = viz.add('vcc_male.cfg') # Add a CAL3D based avatar
character.state(1) # Activate the walking state
viewLink = viz.link( character, view)
viewLink.setDstFlag( viz.LINK_HEAD)
viewLink.preTrans( [-.4, .1, 0] )
vizact.whilekeydown(viz.KEY_UP,character.rotate,1, 0,0,vizact.elapsed(-15),viz.REL_PARENT)
vizact.whilekeydown(viz.KEY_DOWN,character.rotate,-1,0,0,vizact.elapsed(-15),viz.REL_PARENT)
vizact.whilekeydown(viz.KEY_RIGHT,character.rotate ,0,1,0,vizact.elapsed(15),viz.REL_PARENT)
vizact.whilekeydown(viz.KEY_LEFT,character.rotate, 0,1,0,vizact.elapsed(-15),viz.REL_PARENT)
def characterWalk (key):
if key == 'r':
character.state(2)
walk = vizact.walkTo([10,0,0],1,45)
character.addAction(walk)
viz.callback(viz.KEYBOARD_EVENT, characterWalk)
secondView = viz.addView()
secondView.setPosition(10,2,20)
secondView.rotate(220)
def anotherView (key):
if key == 'v':
viz.MainWindow.viewpoint(secondView)
viz.callback(viz.KEYBOARD_EVENT, anotherView,priority=1)
Old 03-11-2009, 11:06 PM
I found the solution
Old 03-12-2009, 12:18 AM
I was able to make my view move and rotate correctly, but the problem is that I can't fix my view to be beside the avatar's head. and I also want to press a key for example 'r' and move the character to a certain point but anything I tried didn't work at all.
Please take a look at my code:
viz.clearcolor(0.5,0.5,1)
MOVE_SPEED = 5 # how fast the viewpoint move
TURN_SPEED = 60 # how fast the view point rotate
char = viz.add('vcc_male.cfg')
char.state(1)
view = viz.MainView
view.setPosition(0,1.7,0)
car = viz.add('mini.osgx')
car.translate(5,0,5)
def mytimer(num):
if viz.iskeydown(viz.KEY_DOWN):
view.move(0,0,-MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
elif viz.iskeydown(viz.KEY_UP):
view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_OR I)
elif viz.iskeydown(viz.KEY_RIGHT):
view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BOD Y_ORI,viz.REL_PARENT)
elif viz.iskeydown(viz.KEY_LEFT):
view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.REL_PARE NT)
updatechar()
def updatechar():
#translate the character to the position of the viewpoint
char.translate(view.get(viz.HEAD_POS))
#rotate the character to the same orientation as the BODY_ORI.
char.rotate(view.get(viz.BODY_AXISANGLE))
#move the character beside the view.
char.translate(0,-0.35,0,viz.REL_LOCAL) #viz.REL_LOCAL. This tells vizard to translate the car relative to its local coordinate system (i.e. relative to the direction the car is facing).
def mousemove(e):
#gets the Euler angle rotation of the HEAD_ORI
euler = view.get(viz.HEAD_EULER)
#adding the x movement of the mouse to the current yaw(we multiply the x movement by 0.1. This is to decrease the sensitivity of the movement)
euler[0] += e.dx*0.1
#adds the y movement of the mouse to the current pitch. We need to negate the value since a positive pitch value means rotating down, but moving the mouse down means having a negative y movement.
euler[1] += -e.dy*0.1
#clamping the pitch value between -90 and 90, since we don't want to let the user look down or up so much that they end up upside down.
euler[1] = viz.clamp(euler[1],-90.0,90.0)
#rotating the HEAD_ORI of the viewpoint by the new euler angle rotation
view.rotate(euler,viz.HEAD_ORI)
viz.callback(viz.MOUSE_MOVE_EVENT,mousemove)
#Turn off built in mouse
viz.setMouseOverride()
#Hide cursor
viz.cursor(viz.OFF)
def mousedown(button):
view.reset(viz.HEAD_ORI)
elif button == viz.MOUSEBUTTON_RIGHT:
view.reset(viz.BODY_ORI|viz.HEAD_POS)
updatechar()
viz.callback(viz.MOUSEBUTTON_EVENT,mousedown)
Old 03-12-2009, 12:38 AM
sorry about the code I can't get the code indentation. please tell me how to do that.
Old 03-12-2009, 06:25 AM
moooh moooh is offline
just post the code inbetween the code tags [ code] code goes here [ /code]
without the extra spaces I added in order for the tags to show up as text
view problem nlfrnassimi Vizard 3 03-11-2009 09:33 PM
Manipulating Tracker View Micha Vizard 3 02-25-2008 11:05 AM
problem with stereo mode shivanangel Vizard 3 10-17-2006 10:58 AM
Moving view with object Xliben Vizard 2 07-25-2005 06:36 PM
keeping a 3d object in front of the view tavaksai Vizard 1 07-07-2004 10:33 AM
