Old 09-15-2008, 06:35 AM
digitaldarklord digitaldarklord is offline
Send a message via MSN to digitaldarklord Send a message via Skype™ to digitaldarklord
64 bit tracker ?
Greetings
I ve managed to buy a HMD and it works. But I have a major problem with a product called minuteman. This system is not compatible with 64 bit windows xp.
I need to track the HMD. Does anyone know a cheat and stable solution in combination with worldviz ?
Thanks in advance
I.
Old 09-15-2008, 06:10 PM
You can connect the minuteman to a 32-bit windows machine and send the tracking data over the network to the 64-bit machine. It's the only work around I can think of.
Old 10-01-2008, 02:54 AM
;-) Tracking cheat
Hi
Just to know for sure if it works...
Could you help me with a snippet just to send the tracking data to the simulation computer ?
Just a snippet with the networking demo that works
#Add a room.
court = viz.add('court.ive')
#Add an avatar for your friend.
other = viz.add('vcc_male.cfg')
############# Add networking ####################
#Name your opponent.
OTHER_COMPUTER = 'vistameuk'
#Add a network for sending data to your other computer.
other_net = viz.addNetwork( OTHER_COMPUTER )
#Send mailox.
def send_box():
#Send the position of the
#cueball to the master.
ori = viz.MainView.getEuler()
other_net.send( other_pos = pos, other_ori = ori )
#Send the data to the master as frequently as possible.
vizact.ontimer(0, send_box )
#Add a network to listen to the data.
def onNetwork(e):
global current_animation
#This function will handle network
#events.
if e.sender == OTHER_COMPUTER:
#Set the position of the other in your world.
other.setPosition( e.other_pos )
other.setEuler( e.other_ori )
#other.state( e.current_animation )
viz.callback(viz.NETWORK_EVENT,onNetwork)
def onKeyDown(key):
current_animation = eval( key )
So if you start the let's say tracker listener you need to invoke tracking on that machine and send the data to the mainview
While I am not just to send tracking data help would be nice
Old 10-02-2008, 11:36 AM
The script sending the data out should look something like this:
#Connect to tracker
tracker = ...
#Create network object for sending tracking data
network = viz.addNetwork('ComputerName')
#Setup timer to output send data every frame
def SendTrackingData():
	pos = tracker.getPosition()
	quat = tracker.getQuat()
	network.send(pos=pos,quat=quat)
vizact.ontimer(0,SendTrackingData)
Your simulation script should contain the following code for retrieving the data over the network:
#Create empty node that will contain remote tracker data
remoteTracker = viz.addGroup()
#Setup callback to handle network event
def onNetwork(e):
	remoteTracker.setQuat(e.quat)
	remoteTracker.setPosition(e.pos)
#Now use remoteTracker object like any other tracker
viz.link(remoteTracker,viz.MainView)
Problem with tracker after reboot eugcc Precision Position Tracker (PPT) 4 08-04-2009 12:26 AM
Crashing when I select Tracker option GoldenSun Vizard 4 07-01-2008 12:06 PM
tracker commands frequency over the JimB Vizard 3 03-07-2008 10:33 AM
Interface with Tobii Eye Tracker Uttama_vizard Precision Position Tracker (PPT) 1 12-12-2007 12:31 PM
Can Vizard interact with the Arrington eye tracker? Deltcho Vizard 1 09-18-2007 03:38 PM
