Old 08-22-2017, 07:05 AM
mms mms is offline
cave distortion
is there a way to turn off the cave distortion correction or is it possible to apply the same distortion used in the cave configuration for a subwindow?
Best regards
Old 08-22-2017, 10:24 PM
Can you explain what you are trying to do and the complete hardware setup?
Yes, that's how the CAVE single machine example script is setup.
Old 08-24-2017, 04:59 AM
mms mms is offline
I like to disable the distortion effect which is shown in this picture.
You can find this picture in the vizard 5 documentation in section “Position/Orientation tracking” of chapter “vizcave basics”, too.
Old 08-26-2017, 12:40 AM
If you set the head tracker of the CAVE to a fixed position there will be no updates to the projection matrices. You can still move the CAVE origin around. Here's an example using the powerwall script:
Use arrow keys and mouse
to move the viewpoint
import vizcave
import viztracker
import vizinfo
vizinfo.InfoPanel()
#Dimension of PowerWall in meters
WIDTH       = 3.0
HEIGHT      = 3.0
DISTANCE    = 2.0
#Create single power wall
PowerWall = vizcave.Wall(   upperLeft=(-WIDTH/2.0,HEIGHT,DISTANCE),
						 upperRight=(WIDTH/2.0,HEIGHT,DISTANCE),
						 lowerLeft=(-WIDTH/2.0,0.0,DISTANCE),
						 lowerRight=(WIDTH/2.0,0.0,DISTANCE),
						 name='Power Wall' )
cave = vizcave.Cave()
cave.addWall(PowerWall)
# Set a fixed position for the cave tracker
head_tracker = viz.addGroup(pos=[0,1.8,0])
cave.setTracker(head_tracker)
cave_origin = vizcave.CaveView(head_tracker)
origin_tracker = viztracker.KeyboardMouse6DOF()
origin_link = viz.link(origin_tracker, cave_origin)
#Add gallery environment model
viz.add('gallery.osgb')
Four Wall Cave using two client cluster JB_HP_Viz Vizard 3 05-13-2016 04:26 AM
anaglyph effect at front view of cave g.vannan Vizard 1 02-03-2015 06:29 AM
Cave Collision problem TopazFrost Vizard 2 02-13-2014 03:34 PM
[New here] Cave joy navigation esuna114 Vizard 2 06-11-2010 05:36 PM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 11:12 AM
